XProtect Hardening guide
Version history
Last Updated: 3 minute read
Versionver25
LanguageEnglish
Document version
Release
Comments
Version 25
2026 R1
Removed references to Log Server. As of 2026 R1, the Log Server was replaced by an OpenTelemetry-based logging architecture.
Version 24
2025 R3
Added a new section related to Cyber Assurance (CAPSS): Cyber Assurance (CAPSS)
Added a note about wireless connectivity not being allowed in CAPSS deployments in Basic steps – Network and Advanced steps – Network. Added a note about a mandatory security requirement for how cameras must communicate in a CAPSS‑compliant deployment in Basic steps – Devices.
Version 23
2025 R2
2025 R1
2024 R2
2024 R1
2023 R3
2023 R2
No changes to this document
Version 22
2023 R1
Added hardening information for the SQL Server connection in Connection to the SQL Server databases.
Updated information about the UseRemoting option in Disable legacy remoting channel.
Version 21
2022 R3
Version 20
2022 R2
Added information on Disable IIS header information on the Identity Provider.
Warning removed stating that the Mobile Server is not configurable when the Management Server is in a cluster from Use a "demilitarized zone" (DMZ) to provide external access.
Version 19
2022 R1
Added information about Encryption of communication with the Event Server.
Version 18
2021 R2
Added new section CIS Microsoft IIS 10 benchmark.
Version 17
2021 R1
Updated reference to Microsoft Security Update Guide to https://msrc.microsoft.com/update-guide.
Added new section Configure the Content Security Policy (CSP).
Updated restrictions to Mobile Server in a DMZ in Use a "demilitarized zone" (DMZ) to provide external access.
Version 16
2020 R3
Updated new supported FIPS compliant drivers in Supported drivers.
Version 15
2020 R3
Added new sections FIPS 140-2 compliance and Drivers and FIPS 140-2.
Added information on Disable the IIS Default Page.
Updated information on Disable IIS HTTP TRACE / TRACK verbs.
Port 25 for the recording server and failover recording server is deprecated. See Use firewalls to limit IP access to servers and computers.
Version 14
2020 R2
Added information to deny access to X-Frames in Manage IIS header information.
Version 13
2020 R2
Added information about encryption between the management server and the data collector.
Added information on Disable IIS HTTP TRACE / TRACK verbs.
Version 12
2020 R1
Microsoft Internet Explorer no longer supported. Microsoft Edge is supported. See Use only supported browsers with the latest security updates.
Version 11
2019 R3
Port 5432 is disabled by default.
Added information on Disable IIS header information.
Version 10
2019 R2
Added section Secure communication
  • Management server encryption
  • Recording server data encryption
  • Mobile server data encryption
Added hardening information for the SQL Server database connection in Connection to the SQL Server databases.
Added hardening information for Recording Server in Harden Network Attached Storage (NAS) to store recorded media data.
Version 9
2019 R1
Added encryption from the recording server to all clients, described here: Recording server data encryption
Version 8
2018 R3
Added design recommendations, described here: Privacy by design.
Log Server uses port number 22337.
Mobile server no longer uses port 8000 for communication with Tray Manager.
New recommendation for scanning for devices, described in Scanning for devices.
Version 7
2018 R2
Version 6
2018 R1
Clarified the need to add specific firewall rules to the Management Server.
Version 5
2018 R1
Version 4
2017 R3
Version 3
2017 R2
This document applies to XProtect VMS versions 2017 R2 and before.
These are the changes to the document:
Version 2
2016 R3
This document applies to XProtect VMS versions 2016 R3 and before.
Version 1
2016 R2
