XProtect Hardening guide
Drivers and FIPS 140-2
Last Updated: 5 minute read
Versionver24
LanguageEnglish
This section discusses FIPS 140-2 and how to configure and use the Milestone drivers to operate in FIPS 140-2-compliant mode.
Requirements for FIPS 140-2 compliant mode
Device requirements
For a device to be able to communicate with a driver running in FIPS 140-2 compliant mode it must fulfill all of these:
  • The device must support HTTPS communication with at least one FIPS 140-2 compliant cipher suite (for examples see Example of FIPS 140-2 compliant cipher suites)
  • The device must support RTSP over HTTPS (Tunneling RTSP and RTP over HTTP) using HTTP Basic Authentication (RFC2068 Section 11.1) or HTTP Digest Authentication (RFC2069, RFC7616)
    or
    The device must support media streaming using SRTP and RTSPS (RFC3711)
Supported drivers
Currently only a subset of drivers is FIPS 140-2 compliant. These drivers support communication through a secured channel for all available features.
Axis 1 channel
Axis 1 channel PTZ
Axis 2 channel
Axis 3 channel
Axis 4 channel
Axis 8 channel
Axis 11 channel
Axis 12 channel
Axis Audio
Bosch PTZ
Bosch 1 channel
Bosch 2 channel
Bosch 3 channel
Bosch 16 channel
Bosch X20XF
Bosch X40XF
Canon 1 channel
Canon 1 channel PTZ
Canon VBM
Canon VBM 40
Canon VBS
Canon VBS No Ptz
Digital Barriers TVI Decoder
Hanwha Generic
ONVIF
ONVIF16
Universal
Universal 16 channel
Universal 64 channel
VideoPush
The drivers in the table are capable of running in FIPS 140-2 compliant mode when configured properly. This list is not final and may expand in the future. Some drivers are FIPS 140-2 compliant with limited capabilities. Refer to specific driver sections below for information on how to configure them and any limitations.
FIPS 140-2 compliant mode for drivers is available since Device Pack 11.1.
Effects of running in FIPS 140-2 compliant mode
When operating in FIPS 140-2 compliant mode, some drivers will be unavailable for use. Drivers which are listed as FIPS 140-2 might not be able to connect to devices that do not fulfill the device requirements.
A driver is FIPS 140-2 compliant and the communication with the device is FIPS 140-2 compliant if the FIPS 140-2 capable driver:
If any of the requirements for FIPS 140-2 compliant mode are not fulfilled, then there is no guarantee about the FIPS 140-2 compliancy of the driver or the communication with the device.
How to configure the device and the driver for FIPS 140-2
The configuration of the device and driver for FIPS 140-2 compliant mode is device and driver specific. Some general guidelines apply:
  • The communication channels between the driver and the device must be secure and encrypted (HTTPS, RTSP over HTTPS, SRTP).
  • The device must be configured for operation using secure channels.
  • The driver and device must be configured to use secure channels for communication in XProtect VMS.
Axis drivers
Do the following:
  • Set HTTPS Enabled to Yes.
  • Set HTTPS Validate Certificate to Yes.
  • Set HTTPS Validate Hostname to Yes.
  • For every enabled media channel and media stream, set Streaming Mode to RTP/RTSP/HTTP/TCP.
Canon drivers
  • Set the HTTPS Enabled to Yes.
Bosch drivers
Do the following:
  • For every enabled media channel and media stream, set Streaming Mode to one of the following:
    • RTP/RTSP/HTTP/TCP
    • SRTP/RTSPS/UDP
    • SRT/RTSPS/UDP multicast
Hanwha drivers
  • For every enabled media channel and media stream, set Streaming Mode to HTTP streaming.
ONVIF drivers
Do the following:
  • For every enabled media channel and media stream, set Streaming method to RTP/RTSP/HTTP/TCP.
  • The Audio backchannel (Audio Out, Device Speaker) must not be used when the driver is running in FIPS 140-2 compliant mode.
Universal drivers
Do the following:
  • For every enabled media channel and media stream, set Streaming Mode to either RTP/RTSP/HTTP/TCP or HTTP, depending whether streaming or snapshot retrieval mode is used.
VideoPush driver
No specific configuration is needed. Enabling the FIPS Group Policy will force the driver to communicate with the XProtect Mobile serverin a FIPS 140-2 compliant way.
0x1302
TLS_AES_256_GCM_SHA384
0x1303
TLS_CHACHA20_POLY1305_SHA256
0x1301
TLS_AES_128_GCM_SHA256
0xC02C
TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
0xC030
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
0x00A3
TLS_DHE_DSS_WITH_AES_256_GCM_SHA384
0x009F
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
0xC02B
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
0xC02F
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
0x00A2
TLS_DHE_DSS_WITH_AES_128_GCM_SHA256
0x009E
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
0xC024
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
0xC028
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
0x006B
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
0x006A
TLS_DHE_DSS_WITH_AES_256_CBC_SHA256
0xC023
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
0xC027
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
0x0067
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
0x0040
TLS_DHE_DSS_WITH_AES_128_CBC_SHA256
0x00AD
TLS_RSA_PSK_WITH_AES_256_GCM_SHA384
0x00AB
TLS_DHE_PSK_WITH_AES_256_GCM_SHA384
0x009D
TLS_RSA_WITH_AES_256_GCM_SHA384
0x00A9
TLS_PSK_WITH_AES_256_GCM_SHA384
0x00AC
TLS_RSA_PSK_WITH_AES_128_GCM_SHA256
0x00AA
TLS_DHE_PSK_WITH_AES_128_GCM_SHA256
0x009C
TLS_RSA_WITH_AES_128_GCM_SHA256
0x00A8
TLS_PSK_WITH_AES_128_GCM_SHA256
0x003D
TLS_RSA_WITH_AES_256_CBC_SHA256
0x003C
TLS_RSA_WITH_AES_128_CBC_SHA256
0x0035
0x002F
Note
This list is not exhaustive. There are other cipher suites that are FIPS 140-2 compliant. This list is given only as a sample of cipher suites that are FIPS 140-2 compliant.
