The Information pane
The Information pane displays the configured metaform, allowing you to enter metadata related to the case.
A | Information pane | This pane displays the configured metaform with the desired fields. |
B | Metaform fields | The fields can be configured to be optional or required, as a choice/dropdown, or as short or long text. |
