XProtect Manager Plug-in
The Case view
Version2.1
LanguageEnglish
Using the Case View, you can add new cases, view your cases, and archive or rename your cases.
A
Add case
Clicking the +Add button will give you the option to create and name a new case or ingest a Case-Pak.
B
View case
When you select or highlight a case, the details will be displayed in the Tree pane.
C
Rename or delete case
You can right-click on a case, and a pop-up window will appear, giving you the option to Rename this case or to Delete this case.
