Installing the plugin
You can install the plugin on every relevant XProtect Smart Client.
Milestone recommends installing the plugin through an MSI push, but you can install it manually if needed.
There is no configuration needed for it, unless the service is located on a machine different than the XProtect Management Server, in which case the machine's address is required.
