XProtect Manager Plug-in
Installing the plugin
Version1.0
LanguageEnglish
You can install the plugin on every relevant XProtect Smart Client.
  • Milestone recommends installing the plugin through an MSI push, but you can install it manually if needed.
  • There is no configuration needed for it, unless the service is located on a machine different than the XProtect Management Server, in which case the machine's address is required.
