Milestone Customer Dashboard
Register software license codes (SLCs)
If you register a software license code (SLC) in Milestone Customer Dashboard, you can:
  • Track the licenses that you sell to customers.
  • Assign licenses to customers.
  • Set up monitoring of your customers' VMS installations.
Important
Distributor, resellers, integrators and end-users can all register licenses. Each role can only register a license once.
To register an SLC:
  1. Log in to Milestone Customer Dashboard (https://online.milestonesys.com/).
  2. In the main menu, select Licenses or Customers1.png, then select Register new license (SLC)2.png.
    The licenses page in Milestone Customer Dashboard.
  3. In the Register new license window, in the License code (SLC) field, enter the SLC 3.png.
  4. In the MAC address of the server that was used for activation field, enter the MAC address of the server that you used to activate the license on 4.png.
  5. Click Next5.png.
    The Register new license window.
  6. Optional: In the License group field, assign the SLC to an existing license group 6.png.
  7. Optional: In the License description field, enter a custom description of the license 7.png.
    Note
    You can search by license description on the Licenses page in the Search field.
  8. To associate the SLC with a customer 8.png:
    • For an existing customer, select a customer in the Customer list
    • For a customer that has not yet been created in Milestone Customer Dashboard, select Add customer, enter a new customer name, and select Save
    Note
    Only distributors, resellers and integrators can associate SLCs with customers.
  9. Select Register SLC9.png. The new license is added to the Licenses list.
    The Register new license window after an SLC and MAC address have been provided.
