Milestone AI Bridge administrator manual
Ports used by the integration
Versionv3.0.1
LanguageEnglish
Illustration showing the different ports and protocols in a Milestone AI Bridge integration.
Ports used by the XProtect VMS
Port number
Protocol
Owner
Purpose
80
SOAP
The Management Server service
Configuration.
The purpose of port 80 and 443 is the same.
  • Unsecured communication: use port 80.
  • Secured communication: use port 443.
443
SOAP
22331
SOAP
The Event Server service
Events.
7563
IS
The Recording Server service
Video.
SOAP
Status API.
Ports used by Milestone AI Bridge
The port numbers vary depending on whether the processing servers use Kubernetes or Docker Compose.
Docker Compose
Port number
Protocol
Owner
Purpose
3500
REST
Milestone AI Bridge Health container
Health check of processing servers.
8787
VPS
Milestone AI Bridge Proxy container
Video and metadata.
Kubernetes
Port number
Protocol
Owner
Purpose
80
SOAP and API Rest
nginx-gateway-controller
Health check of processing servers. Video and metadata.
The purpose of port 80 and port 443 is the same.
443
SOAP and API Rest
Ports used by the IVA applications
When an IVA application registers itself on Milestone AI Bridge, the IVA application often also provides a URL to web page displayed in XProtect Management Client. For information on which other ports are used by an IVA application to communicate with Milestone AI Bridge, consult the documentation for the IVA application.
Port number
Protocol
Owner
Purpose
Individual for each IVA application
HTTP or HTTPS
IVA application
Web page made available in XProtect Management Client where you can draw the graphical representation of the selected analytics topic on top of the video from the camera.
Requires Microsoft Edge WebView2.
