Milestone AI Bridge administrator manual
Initial configuration tasks
Before you install or immediately after you install the patch for XProtect Management Client and the Processing Server Admin plugin (VideoOS.ProcessingServer.Plugin.Admin.Installer), there are a few configuration tasks that you typically define once.
  • Create the AI Bridge role (optional but recommended).
    Create a basic user and assign to the AI Bridge role so Milestone AI Bridge can connect with your XProtect VMS.
  • Secure the connections between Milestone AI Bridge and your XProtect VMS.
  • Define a retention time for events to comply with GDPR or other laws concerning personal data.
