Viewing LPR related content
LPR in live mode
In live mode, you can view live video from the cameras that have been configured for license plate recognition (LPR). You can view video from several LPR cameras in a view at the same time. On the right-hand side of the view item, the LPR events appear whenever there is a match. In setup mode, you can change the settings that define how the list of license plate numbers displays.
When you click a license plate in the LPR event list, the live video automatically pauses and changes to independent playback. To go back to viewing live video, either click the license plate again or click the Independent playback icon on the camera toolbar.
LPR on the Search tab
On the Search tab, you can search for video recordings associated with vehicles.
The LPR tab
LPR 標籤上,您可以從所有 LPR關閉 「車牌辨識」的簡稱。 攝影機調查 LPR 事件,並檢視相關的視訊錄影和車牌辨識資料。將比對清單保持在最新狀態,並建立報告。
該標籤包含 LPR 事件清單和 LPR 攝影機預覽。在預覽中,您可以檢視與 LPR 事件詳情有關的視訊。車牌的相關資訊以及與其相關之比對清單中的詳細資料和車牌樣式會一起出現在預覽底下。
您可以根據期間、國家/地區模組、LPR 攝影機、比對清單或車牌樣式篩選事件清單。使用搜尋註冊號碼欄位搜尋特定的車牌註冊號碼。根據預設,此清單會顯示前一個小時的 LPR 事件。另請參閱LPR event list
可以指定相关事件并将其导出为 PDF。
您可以使用比對清單功能,更新現有的比對清單。
LPR event list
The LPR關閉 「車牌辨識」的簡稱。 event list displays all LPR events. By default, the list displays LPR events from the last hour and with the newest at the top, but your system administrator can change this.
When you select an LPR event from the list, you can see a preview to the right with the related video sequence for the event. The title bar of the preview shows the name of the LPR camera that the LPR event was triggered from. You also see the:
  • License plate number
  • Country module
  • Time of the event
  • Match list that triggered the event
  • License plate style (see License plate styles)
You can change how the LPR event list displays events; you can sort the columns and you can drag them to different positions. You can use the filters at the top of the list to filter LPR events or use the Search registration number field to search.
The LPR event list only displays LPR events from the time of your search or filter. If you want to see the latest LPR events, click the Refresh button.
車牌樣式是車牌的一組特徵。這些特徵包括:
  • 車牌尺寸和形狀
  • 文字格式和字型
  • 顏色
  • 使用車牌的車輛類型。
Your system administrator can group license plate styles and give that group a custom name.
您只能將那些車牌樣式新增到由您的系統管理員分組和命名的比對清單。
Filtering LPR events
There are several ways you can filter the LPR event list, so it displays just the LPR events that you are interested in; you can click any of the filters at the top of the list to see only LPR events associated with that filter. Any filters you apply are immediately reflected in the list.
  • Period: Select one of the available periods to see LPR events within that particular time
  • Country module: Clear or select country modules to view only LPR events linked to a license plate from a particular country, state, or region
  • LPR camera: Select one or more of the available LPR cameras to view only LPR events for those cameras
  • Match list: Select one or more license plate lists to view only LPR events generated by those lists
  • License plate style: Select one or more license plate styles to view only LPR events associated with those license plate styles
You can combine the filters, for example, for a particular country module on a certain date.
You can also use the Search registration number field to search for a particular license plate. Enter a combination of characters to find results with combinations of those characters. For example, if you enter the characters XY 12 you will get license plates that have both XY and 12 in their number. If you enter XY12 you will only get license plates that have XY12 in their number.
Edit match lists
You can add and delete license plates from match lists.
  1. On the LPR tab, in the top-right corner of the window, click Match lists to open the Match lists dialog box.
  2. In Select match list, select the list that you want to edit.
  3. To add a license plate registration number or a license plate style, click Add. Enter relevant information and click OK.
  4. To edit an existing license plate registration number, you can use the search function to find the relevant registration number.
  5. Double-click a single row to edit or select multiple rows and click Edit.
  6. In the dialog box, enter information and click OK. If the match list contains muliple columns, you can edit the information in all fields.
  7. To remove a license plate registration number, you can use the search function to find the relevant registration number.
  8. Select multiple rows if needed and click Delete.
  9. Click Close.
Alternatively, you can add a license plate to a match list by right-clicking an unlisted LPR event and selecting Add to list. You can also remove a license plate by selecting the relevant LPR event, and on the right, below the preview, clicking the Remove from list icon.
Import or export match lists
You can import a file with a list of license plates that you want to use in a match list. You have the following import options:
  • Add license plates to the existing list
  • Replace the existing list
This is useful if, for example, the lists are managed from a central location. Then they can keep all local installations updated by distributing a file.
Similarly you can export the complete list of license plates from a match list to an external location.
  1. To import a match list:
    1. On the LPR tab, at the top right of the window, click Match Lists to open the Match Lists dialog box.
    2. Select the relevant list.
    3. To import a file, click Import.
    4. In the dialog box, specify the location of the import file and the import type. Click Next.
    5. Await the confirmation and click Close.
  2. To export a match list:
    1. Click Export.
    2. In the dialog box, specify the location of the export file and click Next.
    3. Click Close.
    4. You can open and edit the exported file in, for example, Microsoft Excel.
Supported formats are .txt or .csv.
Export LPR events as a report
You can export a report of LPR關閉 「車牌辨識」的簡稱。 events to a PDF file.
  1. On the LPR tab, filter or search for the events you want to include in the report.
    If the number of found events is very high, you will receive a recommendation to refine the search and thereby reduce the number of search results.
  2. Click the LPR Report button.
  3. Specify the following values and click OK:
    • Report name
    • Report destination
    • A comment field
    • An option to include snapshots
    A progress bar appears at the top right of the XProtect Smart Client window.
  4. Click Details to view the report.
If you want to change the paper format or font, open the Settings window, select Advanced, and change the PDF report format or PDF report font settings.
LPR on the Alarm Manager tab
On the Alarm Manager tab, you can view and investigate alarms related to LPR. Some customization is required before you can view the information:
In general, read the sections about alarm management for more details on XProtect Smart Client functionality.
View LPR recognitions
You can view LPR recognitions in the alarm list. If you select events as the data source, all recognitions are displayed. If you select alarms as the data source, only the recognitions associated with an alarm are displayed.
  1. Go to the Alarm Manager tab.
  2. Click the Setup button to enter setup mode.
  3. To view recognitions associated with an alarm:
    1. In the Data Source list, select Alarm.
    2. 再次選擇設定以結束設定模式並儲存變更。 The recognitions are displayed in the alarm list.
    3. To view incoming LPR alarms, enter LPR in the Type field.
      View license plate recognitions in XProtect Smart Client.
  4. To view all recognitions:
    1. In the Data Source list, select Event.
    3. To view all incoming LPR events, enter LPR in the Type field.
The alarm list will display the filtered results only when you leave the field you modified.
Show or hide vehicle properties on the LPR tab
When you look at the match lists on the LPR tab, vehicle properties such as make, model, and type of vehicle are included by default in the results.
However, you might want to hide them in certain scenarios where these properties are not related to your use of XProtect LPR.
To switch between showing and hiding vehicle properties:
  1. On the LPRtab, right-click any column header in the list, for exampleMake or Model, and select Hide vehicle properties. Vehicle properties are now hidden.
  2. To show vehicle properties again, right-click any available column header, then select Show vehicle properties. They are now displayed again.
