Replace a camera but keep its settings
You can replace a camera in a view but retain the settings for that view item.
  1. 在工作区工具栏中,选择设置
  2. In the Views pane, select the view and camera view item to replace.
  3. In the Properties pane, select the ellipses button next to the Camera name field.
  4. Select the new camera.
  5. 再次选择设置可退出设置模式并保存修改。
