Configure playback of gaps between recordings
You can adjust how the main timeline plays back gaps between recordings.
If, for example, all cameras in a view have no recordings in the same period, there is no need to play back the non-recordings at average speed. Therefore, the timeline is, by default, configured to skip the playback of gaps between recordings. If you want to change this behavior, you can.
В глобальной панели инструментов выберите Настройки и дополнительно, а затем Настройки.
In the Settings window, select Timeline.
Set the Playback option to either Skip gaps or Do not skip gaps.
