Get started
Before you can start using XProtect Smart Wall, you need to:
  1. Get and activate a base license for XProtect Smart Wall. See also XProtect Smart Wall licensing.
  2. Configure XProtect Smart Wall and set the user permissions in XProtect Management Client. See also Configuring XProtect Smart Wall and Specify user permissions for XProtect Smart Wall.
  3. Optionally, you can make the Smart Wall controlClosedGraficzne przedstawienie ściany wideo, które umożliwia sterowanie zawartością wyświetlaną na różnych monitorach. available to operators in XProtect Smart ClientSee also Setting up XProtect Smart Wall in XProtect Smart Client.
