GPS coordinates tab (Access Control)
When you add the GPS coordinates for an access control unit, the unit automatically appears on the smart maps in XProtect Smart Client.
Name |
Description |
| Access control units | Select the access control unit you want to add GPS coordinates for. |
GPS coordinates |
Enter the GPS coordinates of the access control unit in the format latitude, longitude. The value you enter determines the position of the access control unit icon on the smart map in XProtect Smart Client. |
