OnGuard license options -- PLEASE CONSULT CARRIER FOR LICENSING
To enable the integration the following license options are required in the OnGuard license:
Connection |
OnGuard License Options Needed |
OpenAccess |
OpenAccess Integration (ITM-MLST-001) enabled with an expiration date Partner Integration (IPC-311-MLST01) enabled with an expiration date |
For XProtect Access version 3.5 and up, the supported connection mode is OpenAccess. The OnGuard license must have the OpenAccess license options for the integration to function. If you are upgrading from version 3.4 with a DataConduIT license, please refer to Milestone Knowledge Base article 33277.
