Cardholders tab (Access Control)
Use the Cardholders tab to review available information about cardholders in the access control system.
Name |
Description |
Search cardholder |
Type a cardholder's name. If the name exists in the system, it will appear in the list. |
Name |
Lists the names of the cardholders retrieved from the access control system. |
Type |
Lists the type of cardholder, for example:
If your access control system integration allows adding and deleting image files in XProtect, you can upload images to cardholder profiles. This functionality is useful if the access control system integration does not store any existing cardholder images already.
Not all access control systems support adding cardholder pictures through XProtect.
Name |
Description |
Select picture |
Specify a path to a file with an image of the cardholder. This button is hidden if the integrated access control system manages the images and does not allow image changes in XProtect.
Delete picture |
Click to delete the picture. If the cardholder also had a picture the integrated access control system, this picture will be shown instead. |
