Replace a camera but keep its settings
You can replace a camera in a view but retain the settings for that view item.
Selecteer Instellingen op de werkruimtetaakbalk.
In the Views pane, select the view and camera view item to replace.
In the Properties pane, select the ellipses button next to the Camera name field.
Select the new camera.
Selecteer Instellen opnieuw om de modus Instellingen te verlaten en uw wijzigingen op te slaan.
