Basic steps – Network
Use secure and trusted networks connection
Network communications must be secure, whether or not you are on a closed network. By default, secure communications should be used when accessing the VMS. For example:
Otherwise, credentials may be compromised and intruders might use them to access the VMS.
Configure the network to allow client computers to establish secure HTTPS sessions or VPN tunnels between the client devices and the VMS servers.
Learn more
The following control(s) provide additional guidance:
  • NIST SP 800-53 SI-2 Flaw remediation
  • NIST SP 800-53 CM-6 Configuration Settings
  • NIST SP 800-53 SC-23 Session Authenticity
Use firewalls to limit IP access to servers and computers
Milestone recommends that you use secure connections, and the following additional steps:
  • Use secure device authentication
  • Use TLS
  • Use device whitelisting to authenticate devices
  • Use firewalls to limit network communication between servers and client computers and programs.
All XProtect components and the ports needed by them are listed in individual sections below. To ensure, for example, that the firewall blocks only unwanted traffic, you need to specify the ports that the XProtect VMS uses. You should only enable these ports. The lists also include the ports used for local processes.
They are arranged in two groups:
  • Server components (services)—Offer their service on particular ports which is why they need to listen for client requests on these ports. Therefore, these ports need to be opened in the Windows Firewall for inbound connections.
  • Client components (clients)—Initiate connections to particular ports on server components. Therefore, these ports need to be opened for outbound connections. Outbound connections are typically open by default in the Windows Firewall.
If nothing else is mentioned, ports for server components must be opened for inbound connections, and ports for client components must be opened for outbound connections.
Do keep in mind that server components can act as clients to other server components as well.
The port numbers are the default numbers, but this can be changed. Contact Milestone Support, if you need to change ports that are not configurable through the Management Client.
Server components (inbound connections)
Each of the following sections list the ports which need to be opened for a particular service. In order to figure out which ports need to be opened on a particular computer, you need to consider all services running on this computer.
Restrict remote access to the Management Server by adding firewall rules to only allow Recording Servers to connect to TCP port 9000.
Management Serverサービスと関連プロセス
ポート番号
プロトコル
プロセス
接続元
目的
80
HTTP
IIS
すべてのサーバーおよびXProtect Smart ClientManagement Client
80 番ポートと 443 番ポートの目的は同じです。ただし、VMS がどのポートを使用するかは、通信の安全性を確保するために証明書を使用したかどうかによって異なります。
  • 証明書による通信のセキュリティが確保されていない場合、VMS は 80 番ポートを使用します。
  • 証明書で通信を保護した場合、VMSはイベントサーバーからマネジメントサーバーへの通信を除き、443番ポートを使用します。イベントサーバーからマネジメントサーバーへの通信は、WindowsのSecured Framework(WCF)を使用し、80番ポートでWindows認証を行います。
443
HTTPS
IIS
445
TCP
Management Server サービス
Management Server Manager
Windows Active Directory ユーザーを役割に追加できるようにします。
6473
TCP
Management Server Manager トレイアイコン、ローカル接続のみ。
ステータスの表示とサービスの管理。
8080
TCP
マネジメントサーバー
ローカル接続のみ。
サーバー上の内部プロセス間の通信。
9000HTTPマネジメントサーバーRecording Serverサービスサーバー間の内部コミュニケーション用 Web サービスです。
12345
TCP
システムとMatrix受信者の間の通信。
Management Clientのポート番号は変更できます。
12974
TCP
Windows SNMPサービス
SNMP 拡張エージェントとの通信。
システムが SNMP を適用しない場合でも、他の目的でこのポートを使用しないでください。
XProtect 2014 システム以前のポート番号は6475でした。
XProtect 2019 R2システム以前のポート番号は7475でした。
SQL Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
1433
TCP
SQL Server
Identity Provider経由で構成を保存&取得中。
1433
TCP
SQL Server
Event Server サービス
Identity Provider経由でイベントを保存&取得中。
1433
TCP
SQL Server
Log Server サービス
Identity Provider経由でログエントリを保存&取得中。
Data Collector サービス
ポート番号
プロトコル
プロセス
接続元
目的
7609
HTTP
IIS
マネジメントサーバーコンピュータ上:他の全サーバー上のData Collectorサービス。
その他のコンピュータ上:マネジメントサーバー上のData Collectorサービス。
システムモニター。
Event Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
1234
TCP/UDP
Event Serverサービス
XProtect システムにジェネリックイベントを送信するサーバーすべて。
外部のシステムまたはデバイスからのジェネリックイベントをリスンします。
関連のデータソースが有効な場合のみ。
1235
TCP
Event Server サービス
関連のデータソースが有効な場合のみ。
9090
TCP
Event Server サービス
XProtectシステムにアナリティクスイベントを送信するすべてのシステムまたはデバイス。
外部システムまたはデバイスからのアナリティクスイベントをリスンします。
アナリティクスイベント機能が有効な場合のみ関連。
22331
TCP
Event Server サービス
XProtect Smart ClientおよびManagement Client
構成、イベント、アラーム、およびマップデータ。
22332
WS/WSS
HTTP/HTTPS*
Event Server サービス
API GatewayおよびManagement Client
イベント/ステータス購読、イベントREST API、Websockets Messaging API、アラーム REST API。
22333
TCP
Event Server サービス
MIPプラグインおよびアプリケーション。
MIPメッセージング。
*HTTPS専用エンドポイントにアクセスするために HTTP にアクセスすると、403 エラーが返されます。
Recording Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
5210
TCP
フェールオーバー レコーディングサーバー。
フェールオーバー レコーディング サーバーが実行された後のデータベースの統合。
7563
TCP
XProtect Smart Client, Management Client
ビデオおよび音声ストリーム、PTZ コマンドの取得。
8966
TCP
Recording Server Manager トレイアイコン、ローカル接続のみ。
ステータスの表示とサービスの管理。
9001HTTPRecording Serverサービスマネジメントサーバー
複数のレコーディングサーバーインスタンスが使用されている場合は、それぞれのインスタンスに独自のポートが必要です。追加ポートは9002、9003、などとなります。
11000
TCP
レコーディングサーバーのステータスのポーリング。
12975
TCP
Windows SNMP サービス
SNMP 拡張エージェントとの通信。
XProtect 2014システム以前のポート番号は6474でした。
XProtect 2019 R2システム以前のポート番号は7474でした。
65101
UDP
ローカル接続のみ
ドライバーからのイベント通知をリスンします。
Recording Serverサービスによって上記のRecording Serverサービスへの着信接続に加え、以下への発信接続も確立されます。
  • カメラ
  • NVR
  • リモート相互接続サイト(Milestone相互接続ICP)
Failover Server サービスと Failover Recording Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
5210
TCP
Failover Recording Serverサービス
7474
TCP
Windows SNMP サービス
SNMP 拡張エージェントとの通信。
7563
TCP
8844
UDP
Failover Recording Server サービス間の通信
2つのサーバーの間の通信。
8966
TCP
Failover Recording Server Manager トレイアイコン、ローカル接続のみ。
ステータスの表示とサービスの管理。
8967
TCP
Failover Serverサービス
Failover Server Manager トレイアイコン、ローカル接続のみ。
ステータスの表示とサービスの管理。
8990
HTTP
Failover Serverサービス
Failover Serverサービスのステータスをモニター。
9001HTTPFailover Serverサービスマネジメントサーバーサーバー間の内部コミュニケーション用 Web サービスです。
上記のフェールオーバー サーバー / Failover Recording Serverサービスへの受信接続に加えて、フェールオーバー サーバー / Failover Recording Server サービスは、通常のレコーダー、カメラ、ビデオ プッシュ向けに送信接続を確立します。
Log Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
22337
HTTP
Log Server サービス
レコーディングサーバーを除く、すべての XProtect コンポーネント。
ログサーバーの書き込み、読み取り、構成を行います。
このポートは HTTP を使用しますが、通信は WS-Security 規格を使用してメッセージを保護するメッセージセキュリティで暗号化されます。詳細については、「WCF でのメッセージセキュリティ」を参照してください。
Mobile Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
8000
TCP
Mobile Server サービス
Mobile Server Manager トレイアイコン、ローカル接続のみ。
SysTrayアプリケーション。
8081
HTTP
Mobile Server サービス
Mobileクライアント、Webクライアント、およびManagement Client
ビデオと音声のデータストリームの送信。
8082
HTTPS
Mobile Server サービス
MobileクライアントおよびWebクライアント。
ビデオと音声のデータストリームの送信。
40001 - 40099HTTPMobile Server サービスレコーディング サーバー サービス
Mobile Server ビデオプッシュ。
このポート範囲はデフォルトでは無効になっています。
LPR Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
22334
TCP
LPR Serverサービス
イベントサーバー
認証されたナンバープレートとサーバーのステータスの取得。
接続するには、イベントサーバーに LPR プラグインがインストールされている必要があります。
22334
TCP
LPR Serverサービス
LPR Server Manager トレイアイコン、ローカル接続のみ。
SysTray アプリケーション
Milestone Open Network Bridge サービス
ポート番号
プロトコル
プロセス
接続元
目的
580
TCP
Milestone Open Network Bridgeサービス
ONVIF クライアント
ビデオストリーム構成の認証と要求
554
RTSP
RTSPサービス
ONVIF クライアント
ONVIFクライアントへの要求ビデオのストリーミング。
XProtect DLNA Server サービス
ポート番号
プロトコル
プロセス
接続元
目的
9100
HTTP
DLNA Serverサービス
DLNA デバイス
デバイス検出およびDLNAチャネル構成の提供。ビデオストリームの要求。
9200
HTTP
DLNA Serverサービス
DLNA デバイス
DLNAデバイスへの要求ビデオのストリーミング。
XProtect Screen Recorder サービス
ポート番号
プロトコル
プロセス
接続元
目的
52111
TCP
モニターからビデオの提供。録画サーバー上にカメラと同じように表示され、機能します。
Management Client のポート番号は変更できます。
XProtect Incident Manager service
ポート番号
プロトコル
プロセス
接続元
目的
80
HTTP
IIS
  • 証明書で通信を保護した場合、VMSは443番ポートを使用します。
443
HTTPS
IIS
Learn more
  • NIST SP 800-53 CA-3 System Interconnections
  • NIST SP 800-53 SC-7 Boundary Protection
Use a firewall between the VMS and the Internet
The VMS should not connect directly to the Internet. If you expose parts of the VMS to the Internet, Milestone recommends that you use an appropriately configured firewall between the VMS and the Internet.
If possible, expose only the XProtect Mobile server component to the Internet, and locate it in a demilitarize zone (DMZ) with firewalls on both sides. This is illustrated in the following figure.
Learn more
Connect the camera subnet to the recording server subnet only
Milestone recommends that you connect the camera subnet only to the recording server subnet. The cameras and other devices need to communicate only with the recording servers. For more information, see Recording Server.
Learn more
  • NIST 800-53 SC-7 Boundary Protection
