Privacy masking tab (devices)
Le funzionalità disponibili dipendono dal sistema in uso. Consultare l'elenco completo delle funzioni, disponibile nella pagina di panoramica sul prodotto sul sito web Milestone (https://www.milestonesys.com/products/software/xprotect-comparison/).
The following devices have a Privacy masking tab:
  • Cameras
On the Privacy masking tab, you can enable and configure privacy protection for the selected camera.
Privacy masking tab overview for a selected device.
Tasks on the Privacy masking tab
Name
Description
Privacy masking
Enable/disable privacy masking
Privacy masking (explained)
Permanent mask and Liftable mask
Define, if you want a permanent or liftable privacy mask:
Define privacy masks
Tasks related to Privacy masking
Task
Description
Change the timeout for lifted privacy masks for the Smart Client profile associated with the role that has the permission to lift privacy masks.
Enable or disable the permission to lift privacy masks for a role.
Give users permission to lift privacy masks
Create a devices report with information about your cameras' current privacy masking settings. Create a report of your privacy masking configuration
Privacy masking tab (properties)
Name
Description
Grid size
The selected grid size determines the density of the grid, regardless whether the grid is visible in the preview or not.
Select between the values 8×8, 16×16, 32×32 or 64×64.
Clear
Clears all privacy masks you have specified.
Show grid
Select the Show grid check box to make the grid visible.
Show privacy masks
When you select the Show privacy masks check box (default), permanent privacy masks appear in purple in the preview and liftable privacy masks in green.
Milestone recommends that you keep the Show privacy masks box selected so that you and your colleagues can see the current privacy protection configuration.
Pen size
Use the Pen size slider to indicate the size of the selections you wish to make when you click and drag the grid to select regions. Default is set to small, which is equivalent to one square in the grid.
Permanent mask
Appears in purple in the preview on this tab and on the Motion tab.
Permanent privacy masks are always visible in XProtect Smart Client and cannot be lifted. Can be used to cover areas of the video that never requires surveillance, like public areas, where surveillance is not allowed. Motion detection is excluded from permanent masks.
You specify the coverage of privacy masks as either solid or some level of blurred. The coverage settings apply to both live and recorded video.
Liftable mask
Appears in green in the preview on this tab.
Liftable privacy masks can be lifted in XProtect Smart Client by users with sufficient user permissions. By default, the privacy masks are lifted for 30 minutes, or until the user apply them again. Be aware that the privacy masks are lifted on video from all the cameras that the user has access to.
If the XProtect Smart Client user does not have the permission to lift privacy masks, the system asks for a user with permission to authorize the lift.
You specify the coverage of privacy masks as either solid or a level of blurred. The coverage settings apply to both live and recorded video.
Blurring
Use the slider to select the blurring level of the privacy masks in the clients or set the coverage to solid.
By default, the coverage of areas with permanent privacy masks are solid (nontransparent). By default, liftable privacy masks are medium blurred.
You can inform the client users about the appearance of permanent and liftable privacy masks, so they are able to distinguish.
