Hide/remove Download Manager installer components
You have three options:
- Hide components from the web page by clearing check boxes in the Download Manager's tree structure. The components are still installed on the management server, and by selecting check boxes in the Download Manager's tree structure you can quickly make the components available again
- Remove the installation of components on the management server. The components disappear from the Download Manager, but installation files for the components are kept at C:\Program Files (x86)\Milestone\XProtect Download Manager, so you can re-install them later if required
- Remove installation files for non-required features from the management server. This can help save disk space on the server if you know that your organization is not going to use certain features
