License plate styles and aliases
License plate styles and aliases help you standardize and simplify how the system understands and interprets license plate data.
  • License plate styles define how plate numbers are displayed or grouped based on region, format, or use case. Applying consistent license plate styles helps improve the readability, search accuracy, and system consistency, especially when you work across different regions or formats.
  • Aliases enable you to assign a readable name to a license plate. Instead of tracking a number like ABC123, you can label it as Maintenance Van or Visitor – Jane Doe, making it easier to understand and manage entries.
These tools make it easier for you to search, identify, and respond to relevant vehicles in the system.
