Digital zoom vs. optical zoom (explained)
When you use the digital zoom:
  • The quality of the image gets lower. What you see is pixelated and less clear.
  • The quality of the recording does not change.
  • The zoom level of the recording does not change.
When you use the optical zoom (only for cameras that support optical zoom):
  • The quality of the image that you see does not change.
  • If you use the optical zoom on your camera while recording, the zoom levels used will be reflected in your recording.
