XProtect Access
XProtect Access integrates events from one or more access control systems with the features of the XProtect video management software. You can use XProtect Access with access control systems from vendors that offer a vendor-specific plug-in for XProtect Access.
If you have an Access control tab in XProtect Smart Client, you can access features from the XProtect Access extension.
The incidents registered by access control systems generate events in the XProtect VMS system.
In live mode, you can monitor access control events in real time from the cameras associated with a door. In setup mode, you can customize your Access monitor view items with overlay buttons. In a map view item, you can drag access control units onto the map.
On the Access control tab, you can view and investigate events, door states, or cardholders. You can search or filter on events and review any related footage. You can create a report of the events for exporting.
When a person requests access and if your system is configured for it, a separate notification pops up with a list of related information next to the camera feed. You can trigger access control commands, such as locking and unlocking doors. Available commands depend on your system configuration.
