Server Logs node
System logs (tab)
Each row in a log represents a log entry. A log entry contains a number of information fields:
Name |
Description |
Log level |
Info, warning, or error. |
Local time |
Timestamped in the local time of your system's server. |
Message text |
The identification number for the logged incident. |
Category | The type of logged incident. |
Source type |
The type of equipment on which the logged incident occurred, for example, server or device. |
Source name |
The name of the equipment on which the logged incident occurred. |
Event type |
The type of event represented by the logged incident. |
Audit logs (tab)
Name |
Description |
Local time |
Message text |
Shows a description of the logged incident. |
Permission | The information about whether the remote user action was allowed (granted) or not. |
Source type |
Source name |
User |
The user name of the remote user causing the logged incident. |
User location | The IP address or host name of the computer from which the remote user caused the logged incident. |
Rule-triggered logs (tab)
Name |
Description |
Local time |
Message text |
Source type |
Source name |
Event type |
Rule name | The name of the rule triggering the log entry. |
Service name | The name of the service on which the logged incident occurred. |
