Info tab (roles)
Available functionality depends on the system you are using. See the complete feature list, which is available on the product overview page on the Milestone website (https://www.milestonesys.com/products/software/xprotect-comparison/).
On the Info tab of a role, you can change the following settings:
                                             Name  |
                                             Description  |
| Name |
                                             Enter a name for the role.  |
| Description |
                                             Enter a description for the role.  |
| Management Client profile |
                                             Select a Management Client profile to associate with the role. You cannot apply this to the default Administrators role. Requires permissions to manage security on the management server.  |
| Smart Client profile |
                                             Select a Smart Client profile to associate with the role. Requires permissions to manage security on the management server.  |
| Default time profile |
                                             Select a default time profile to associate with the role. You cannot apply this to the default Administrators role.  |
| Evidence lock profile |
                                             Select an evidence lock profile to associate with the role.  |
| Smart Client login within time profile |
                                             Select a time profile for which the XProtect Smart Client user associated with this role is allowed to log in. If the XProtect Smart Client user is logged in when the period expires, he or she is logged off automatically. You cannot apply this to the default Administrators role.  |
| Allow Smart Client login |
                                             Select the check box to allow users associated with this role to log in to XProtect Smart Client. Access to Smart Client is not allowed by default. Clear the check box to deny access to XProtect Smart Client.  |
| Allow XProtect Mobile client login |
                                             Select the check box to allow users associated with this role to log in to XProtect Mobile client. Access to XProtect Mobile client is not allowed by default. Clear the check box to deny access to XProtect Mobile client.  |
| Allow XProtect Web Client login |
                                             Select the check box to allow users associated with this role to log in to XProtect Web Client. Access to XProtect Web Client is not allowed by default. Clear the check box to deny access to XProtect Web Client.  |
| Login authorization required |
                                             Select the check box to associate login authorization with the role. It means that XProtect Smart Client or the Management Client asks for a second authorization, typically by a superuser or manager, when the user logs in. To enable administrators to authorize users, configure the management server's Authorize Users permission on the Overall Security tab. You cannot apply this to the default Administrators role.  |
| Make users anonymous during PTZ sessions |
                                             Select the check box to hide the names of users associated with this role when they control PTZ sessions.  |
