SQL Server installations and databases (explained)
The management server, the event server, the log server,
Surveillance: Management and event server
Surveillance_IDP: IDP
Surveillance_IM: Incident Manager
LogserverV2: LogServer
The management server and the event server share the same SQL Server database while the log server,
The system installer includes Microsoft SQL Server Express which is a free edition of SQL Server.
For very large systems or systems with many transactions to and from the SQL Server databases, Milestone recommends that you use the Microsoft® SQL Server® Standard or Microsoft® SQL Server® Enterprise edition of SQL Server on a dedicated computer on the network and on a dedicated hard disk drive that is not used for other purposes. Installing SQL Server on its own drive improves the entire system performance.
To see a list of supported SQL Server versions, go to https://www.milestonesys.com/systemrequirements/.
For more information about the Identity Provider, see Identity Provider (explained).
