Remove a recording server
If you remove a recording server, all configuration specified in the Management Client is removed for the recording server, including all of the recording server's associated hardware (cameras, input devices, and so on).
- Right-click the recording server you want to remove in the Overview pane.
- Select Remove Recording Server.
- If you are sure, click Yes.
- The recording server and all of its associated hardware are removed.
