Activate licenses online
If the management server has internet access but you prefer to manually start the activation process, this is the easiest license activation option for you.
- From the Site Navigation pane -> Basics node -> License Information, select Activate License Manually and then Online.
 - The Activate Online dialog box opens:
- If you are an existing user, enter your user name and password
 - If you are a new user, click the Create new user link to set up a new user account. If you have not yet registered your Software License Code (SLC), you must do so
 - Click OK.
If you receive an error message during online activation, follow the instructions on the screen to solve the issue or contact Milestone support.
