Activate licenses offline
If your organization does not allow that the management server has internet access, you must activate licenses manually and offline.
- From the Site Navigation pane -> Basics node -> License Information, select Activate License Manually > Offline > Export License for Activation to export a license request file (.lrq) with information about your added hardware devices and other elements that require a license.
 - The license request file (.lrq) is automatically given the same name as your SLC. If you have several sites, remember to rename the files so you can easily identify which file belongs to which site.
 - Copy the license request file to a computer with internet access and log into our website (https://online.milestonesys.com/) to obtain the activated software license file (.lic).
 - Copy the .lic file you receive to your computer with Management Client. The file has been given the same name as your license request file.
 - From the Site Navigation pane -> Basics node -> License Information, select Activate License Offline > Import Activated License, and then select the activated software license file to import it and thereby activate your licenses.
 - Click Finish to end the activation process.
