Test your Smart Wall configuration
After configuring XProtect Smart Wall in XProtect Management Client, you may want to test the configuration before you start adding the Smart Wall control to your views in XProtect Smart Client.
Steps:
  1. Log in to XProtect Smart Client.
  2. In the Views pane, expand the Smart Wall node.
  3. Select a Smart Wall definition and then one of its monitors. If correctly configured, the main view shows the cameras that the presetClosed A predefined layout for one or more Smart Wall monitors in XProtect Smart Client. Presets determine which cameras are displayed, and how content is structured on each monitor on the video wall. is configured to show.
    View Smart Wall monitor in the main view of XProtect Smart Client.
The example shows a monitor with two cameras.
