Set site properties
You can view and, possibly, edit properties on your home site and its child sites.
  1. In the Management Client, in the Federated Site Hierarchy pane, select the relevant site, right-click, and select Properties.
    The Site Properties window with General and Parent Site tabs.
  2. If needed, change the following:
    General tab (see General tab)
    Parent Site tab (see Parent Site tab) (available on child sites only)
    Due to synchronization issues, any changes made to remote children might take some time to be reflected in the Site Navigation pane.
