General settings
Go to the Access Control menu in the directory tree of the XProtect Management Client. You can check the status of all instances by selecting the root of the Access Control directory.
Click on your CCure 9000 XProtect Access Instance to view or modify the properties of the connection.
A full description of all the properties available is found here: XProtect Access instance connection properties.
