List of abbreviations and terms in this white paper
B-frame |
Bi-directional frame – contains information about changes to the frame compared to the previous and next frame in a GOP |
Codec |
Short for ‘coder-decoder’ – a codec contains information about how to encode and decode audio/video according to the codec’s standard – for instance; MPEG-4, H.264 and H.265 |
CPU |
Central Processing Unit - the component in a computer that carries out the instructions of a computer program |
Device |
Common denomination of cameras, microphones, speakers, and metadata sources in an XProtect VMS |
FPS |
Frames Per Second – number of images per second in the video stream |
GOP |
Group Of Pictures – collection of successive pictures within a MPEG encoded video stream |
GPU |
Graphics Processing Unit - the component in a computer that handles graphics operations, like decoding video and rendering graphics |
H.264 |
MPEG video compression standard – successor to MPEG-4 and predecessor to H.265 |
H.265 |
MPEG video compression standard – successor to H.264 |
HDD |
Hard Disk Drive – a disk drive with spinning plates, storing the data as magnetic information on the plates |
I-frame |
Also known as keyframe – the first image in a GOP. An I-frame is comparable to a JPEG image |
IOPS |
Input/Output operations Per Second – a performance measurement used to characterize storage devices |
JBOD |
Just a Bunch Of Disks - multiple independent hard disk drives |
JPEG |
Joint Photographic Experts Group – a compression standard for still images |
Keyframe |
Also known as I-frame – the first image in a GOP. A keyframe is comparable to a JPEG image |
Media Data |
Video, Audio, and metadata retrieved from connected devices |
MJPEG |
Motion JPEG – a series of JPEG images forming a video stream |
MPEG |
Moving Picture Experts Group – used as a common term covering MPEG-4, H.264 & H.265 codecs in this white paper |
MPEG-4 |
MPEG video compression standard – predecessor to H.264 |
NAS |
Network-Attached Storage - a storage technology providing access to file level storage |
OS |
Operating System |
PCB |
Printed Circuit Board – a board that holds and connects components in electronic devices |
P-frame |
Predictive frame – contains information about changes to the frame compared to the previous frame in the GOP |
RAID |
Redundant Array of Independent Disks – a technology that combines multiple physical disks into one or more logical disks, with support for fault tolerance |
RPM |
Revolutions Per Minute |
SAN |
Storage Area Network – a storage technology providing access to consolidated, block level data storage |
SAS |
Serial Attached SCSI – communication standard for storage devices |
SATA |
Serial ATA – communication standard for storage devices |
SSD |
Solid-State Drive – a disk drive without any moving parts, storing the data in memory chips |
VMD |
Video Motion Detection – the process of detecting movement in video images |
VMS |
Video Management Software |
