Basic steps – Network
Use secure and trusted networks connection
Network communications must be secure, whether or not you are on a closed network. By default, secure communications should be used when accessing the VMS. For example:
Otherwise, credentials may be compromised and intruders might use them to access the VMS.
Configure the network to allow client computers to establish secure HTTPS sessions or VPN tunnels between the client devices and the VMS servers.
Learn more
The following control(s) provide additional guidance:
  • NIST SP 800-53 SI-2 Flaw remediation
  • NIST SP 800-53 CM-6 Configuration Settings
  • NIST SP 800-53 SC-23 Session Authenticity
Use firewalls to limit IP access to servers and computers
Milestone recommends that you use secure connections, and the following additional steps:
  • Use secure device authentication
  • Use TLS
  • Use device whitelisting to authenticate devices
  • Use firewalls to limit network communication between servers and client computers and programs.
All XProtect components and the ports needed by them are listed in individual sections below. To ensure, for example, that the firewall blocks only unwanted traffic, you need to specify the ports that the XProtect VMS uses. You should only enable these ports. The lists also include the ports used for local processes.
They are arranged in two groups:
  • Server components (services)—Offer their service on particular ports which is why they need to listen for client requests on these ports. Therefore, these ports need to be opened in the Windows Firewall for inbound connections.
  • Client components (clients)—Initiate connections to particular ports on server components. Therefore, these ports need to be opened for outbound connections. Outbound connections are typically open by default in the Windows Firewall.
If nothing else is mentioned, ports for server components must be opened for inbound connections, and ports for client components must be opened for outbound connections.
Do keep in mind that server components can act as clients to other server components as well.
The port numbers are the default numbers, but this can be changed. Contact Milestone Support, if you need to change ports that are not configurable through the Management Client.
Server components (inbound connections)
Each of the following sections list the ports which need to be opened for a particular service. In order to figure out which ports need to be opened on a particular computer, you need to consider all services running on this computer.
Restrict remote access to the Management Server by adding firewall rules to only allow Recording Servers to connect to TCP port 9000.
Management Server service and related processes
Port number
Protocol
Process
Connections from...
Purpose
80
HTTP
IIS
All servers and the XProtect Smart Client and the Management Client
The purpose of port 80 and port 443 is the same. However, which port the VMS uses depends on whether you have used certificates to secure the communication.
  • When you have not secured the communication with certificates, the VMS uses port 80.
  • When you have secured the communication with certificates, the VMS uses port 443 except for communication from the event server to the management server. The communication from the event server to the management server uses Windows Secured Framework (WCF) and Windows authentication on port 80.
443
HTTPS
IIS
445
TCP
Management Server Manager.
Enable Windows Active Directory users to be added to roles.
6473
TCP
Management Server Manager tray icon, local connection only.
Showing status and managing the service.
8080
TCP
Management server
Local connection only.
Communication between internal processes on the server.
9000 HTTP Management server Recording Server services Web service for internal communication between servers.
12345
TCP
Communication between the system and Matrix recipients.
You can change the port number in the Management Client.
12974
TCP
Windows SNMP Service
Communication with the SNMP extension agent.
Do not use the port for other purposes even if your system does not apply SNMP.
In XProtect 2014 systems or older, the port number was 6475.
In XProtect 2019 R2 systems and older, the port number was 7475.
SQL Server service
Port number
Protocol
Process
Connections from...
Purpose
1433
TCP
SQL Server
Storing and retrieving configurations via the Identity Provider.
1433
TCP
SQL Server
Event Server service
Storing and retrieving events via the Identity Provider.
1433
TCP
SQL Server
Log Server service
Storing and retrieving log entries via the Identity Provider.
Data Collector service
Port number
Protocol
Process
Connections from...
Purpose
7609
HTTP
IIS
On the management server computer: Data Collector services on all other servers.
On other computers: Data Collector service on the Management Server.
System Monitor.
Port number
Protocol
Process
Connections from...
Purpose
1234
TCP/UDP
Event Server Service
Any server sending generic events to your XProtect system.
Listening for generic events from external systems or devices.
Only if the relevant data source is enabled.
1235
TCP
9090
TCP
Any system or device that sends analytics events to your XProtect system.
Listening for analytics events from external systems or devices.
Only relevant if the Analytics Events feature is enabled.
22331
TCP
Configuration, events, alarms, and map data.
22332
WS/WSS
HTTP/HTTPS*
API Gateway and the Management Client
Event/State Subscription, Events REST API, Websockets Messaging API, and Alarms REST API.
22333
TCP
MIP Plug-ins and applications.
MIP messaging.
*A 403 error will be returned when accessing HTTP to access an HTTPS-only endpoint.
Port number
Protocol
Process
Connections from...
Purpose
5210
TCP
Recording Server Service
Failover recording servers.
Merging of databases after a failover recording server had been running.
7563
TCP
XProtect Smart Client, Management Client
Retrieving video and audio streams, PTZ commands.
8966
TCP
Recording Server Manager tray icon, local connection only.
9001 HTTP Recording Server Service Management server
If multiple Recording Server instances are in use, every instance needs its own port. Additional ports will be 9002, 9003, etc.
11000
TCP
Polling the state of recording servers.
12975
TCP
Windows SNMP service
In XProtect 2014 systems or older, the port number was 6474.
In XProtect 2019 R2 systems and older, the port number was 7474.
65101
UDP
Listening for event notifications from the drivers.
In addition to the inbound connections to the Recording Server service listed above, the Recording Server service establishes outbound connections to:
  • Cameras
  • NVRs
  • Remote interconnected sites (Milestone Interconnect ICP)
Failover Server service and Failover Recording Server service
Port number
Protocol
Process
Connections from...
Purpose
5210
TCP
Failover Recording Server Service
7474
TCP
7563
TCP
8844
UDP
Communication between failover recording server services.
Communication between the servers.
8966
TCP
Failover Recording Server Manager tray icon, local connection only.
8967
TCP
Failover Server Service
Failover Server Manager tray icon, local connection only.
8990
HTTP
Monitoring the status of the Failover Server service.
9001 HTTP Failover Server Service Management server Web service for internal communication between servers.
In addition to the inbound connections to the Failover Server / Failover Recording Server service listed above, the Failover Server / Failover Recording Server service establishes outbound connections to the regular recorders, cameras, and for Video Push.
Log Server service
Port number
Protocol
Process
Connections from...
Purpose
22337
HTTP
Log Server service
All XProtect components except for the recording server.
Write to, read from, and configure the log server.
This port uses HTTP, but the communication is encrypted with message security which uses the WS-Security specification to secure messages. For more information, see Message Security in WCF.
Mobile Server service
Port number
Protocol
Process
Connections from...
Purpose
8000
TCP
Mobile Server Manager tray icon, local connection only.
SysTray application.
8081
HTTP
Mobile clients, Web clients, and Management Client.
Sending data streams; video and audio.
8082
HTTPS
Mobile clients and Web clients.
40001 - 40099 HTTP Mobile Server service Recording server service
Mobile Server Video Push.
This port range is disabled by default.
LPR Server service
Port number
Protocol
Process
Connections from...
Purpose
22334
TCP
LPR Server Service
Event server
Retrieving recognized license plates and server status.
In order to connect, the Event server must have the LPR plug-in installed.
22334
TCP
LPR Server Service
LPR Server Manager tray icon, local connection only.
SysTray application
Milestone Open Network Bridge service
Port number
Protocol
Process
Connections from...
Purpose
580
TCP
Milestone Open Network Bridge Service
ONVIF clients
Authentication and requests for video stream configuration.
554
RTSP
RTSP Service
ONVIF clients
Streaming of requested video to ONVIF clients.
XProtect DLNA Server service
Port number
Protocol
Process
Connections from...
Purpose
9100
HTTP
DLNA Server Service
DLNA device
Device discovery and providing DLNA channels configuration. Requests for video streams.
9200
HTTP
DLNA Server Service
DLNA device
Streaming of requested video to DLNA devices.
XProtect Screen Recorder service
Port number
Protocol
Process
Connections from...
Purpose
52111
TCP
Provides video from a monitor. It appears and acts in the same way as a camera on the recording server.
XProtect Incident Manager service
Port number
Protocol
Process
Connections from...
Purpose
80
HTTP
IIS
  • When you have secured the communication with certificates, the VMS uses port 443.
443
HTTPS
IIS
Learn more
  • NIST SP 800-53 CA-3 System Interconnections
  • NIST SP 800-53 SC-7 Boundary Protection
Use a firewall between the VMS and the Internet
The VMS should not connect directly to the Internet. If you expose parts of the VMS to the Internet, Milestone recommends that you use an appropriately configured firewall between the VMS and the Internet.
If possible, expose only the XProtect Mobile server component to the Internet, and locate it in a demilitarize zone (DMZ) with firewalls on both sides. This is illustrated in the following figure.
Learn more
Connect the camera subnet to the recording server subnet only
Milestone recommends that you connect the camera subnet only to the recording server subnet. The cameras and other devices need to communicate only with the recording servers. For more information, see Recording Server.
Learn more
  • NIST 800-53 SC-7 Boundary Protection
