What's new?
Failover recording server:
You can now configure XProtect Management Server Failover and a failover recording server in a workgroup environment. See Prerequisites for running a recording server or failover recording server on the cluster nodes.
Troubleshooting:
To see a list of the most common issues with XProtect Management Server Failover, go to Troubleshooting XProtect Management Server Failover .
Recording server:
You can now install a recording server on the failover cluster nodes. See Prerequisites for running a recording server or failover recording server on the cluster nodes.
External SQL Server:
You can now connect the XProtect Management Server Failover to your external SQL Server. See SQL Server prerequisites.
Workgroups:
You can now configure the failover cluster in a workgroup environment. See Network and computer prerequisites.
User certificates:
User certificates are no longer required to log in to the failover web console. To log in to the failover web console, you must now install a server certificate and authenticate with a user name and password. See Open the failover web console.
Authentication for the failover web console:
You must authenticate with a password to log in to the failover web console. To set a password during the configuration of the failover cluster, see Configure the failover cluster .
Behavior of a node after restart:
You can set a node to always stop or start after restart, see Change the behavior of a node after restart.
