The failover web console
Use the failover web console to manage the failover cluster. You can access the failover web console from any computer that can connect to Node 1 and Node 2.
How you open the failover web console depends on the computer:
  • On Node 1 and Node 2, double-click the icon of the XProtect Management Server Failover web console on your desktop.
  • On all other computers, type the URL of the failover web console in your browser: http://[computername.domainname]:9010 or https://[computername.domainname]:9453.
    [computername.domainname] is the FQDN of either Node 1 or Node 2.
To log in to the failover web console, you must authenticate with the user name admin and the password you set during the configuration of the failover cluster. If you do not remember your password, see Change the password for authentication.
From the failover web console, you can, for example:
