XProtect VMS prerequisites
Install two identical VMS products under a common user account with administrator permissions. To learn more about the general prerequisites for installing XProtect VMS, see the XProtect VMS administrator manual.
When working in a domain environment, select AD users for the service accounts and only give them the permissions required to run the relevant services.
On both nodes, install the following system components:
Milestone recommends that you install all other server components not mentioned above on different computers.
Depending on your system configuration, consider the following:
  • System configuration password - To assign a system configuration password, use the same password for the VMS installations on both nodes.
