Ports used by XProtect Management Server Failover services and modules
Service |
Default ports |
Purpose |
| safeadmin |
Remote access on UDP port 4800 and local access on UDP port 6259 |
Communicate with other safeadmin instances on other computers. The main and mandatory administration service that is started at boot. |
safewebserver |
Local and remote TCP access on port 9010 for the HTTP web console or port 9453 for the HTTPS web console |
The safewebserver service is a standard Apache web service that is mandatory for running the web console, the distributed comman-line interface, and the <module> checkers. |
safecaserv (optional) |
Local and remote access on TCP port 9001 |
The safecaserv service is a web service for securing the web console with the SafeKit PKI. |
safeagent (optional) |
Local and remote access on UDP port 3600 |
The safeagent service for SNMP v2. |
Failover cluster modules
The ports values of one module are automatically computed depending on its module ID.
Module |
Ports |
Purpose |
heart |
port=8888 +(id-1) |
UDP port used for sending heartbeats between the servers. |
rfs |
safenfs_port=5600 +(id-1)x4 |
TCP port used for replications requests between the servers. |
