XProtect Management Server Failover licenses
XProtect Management Server Failover comes with a three-day demo license.
To use the failover cluster for an unlimited period, register the host names of the nodes and add your XProtect Management Server Failover license.
If you do not add your XProtect Management Server Failover license, the Management Server service will stop after three days.
To obtain a license for XProtect Management Server Failover, contact your reseller.
You can add the license during the failover cluster configuration or afterward. See Add a license for XProtect Management Server Failover.
