Install the server certificate on a computer
Install the server certificate on all computers that will access the failover web console.
- Copy the serverCert.crt file from Node 1 to the computer that needs to access the failover web console.
- Right-click the server certificate and select Install Certificate.
In the Certificate Import wizard, choose the Store Location:
For Node 1 and Node 2, select Local Machine
For all other computers, select Current User
Select Next to continue.
- Select Place all certificates in the following store and specify a folder.
- Select Browse, and then Trusted Root Certification Authorities.
Select OK and Next.
- On the Completing the Certificate Import Wizard dialog, select Finish.
- Verify that the server certificate is listed in the center view of the Trusted Root Certification Authorities subtree.
If you receive a security warning that you are about to install a root certificate, select Yes to continue.
If the import has succeeded, a confirmation dialogue box appears.
