Remove a camera from existing investigation
"I'm about to download these videos, but Camera 1 has no relevant footage. How do I take it out of my investigation?" |
On the Investigations tab, in an existing investigation:
- Hover over the camera that you want to remove from the investigation.
- Click
in the upper-right corner to remove the camera from the investigation. - Click Save.
- In the drop-down list, select Save.
You can also remove a camera from your investigation by opening the camera group view under All cameras (see Remove unnecessary cameras from video playback).
