Sync the time in a detached window with the main window
If you’re investigating an incident, you can ensure that a detached window displays video from the same time as that of the main window.
In the detached window, select Sync time with the main views tab
The main timeline is now hidden in the detached windows.
In the main window, use the main timeline to go back and forth in the video in both the main window and in the detached window.
