Searching for video data
The search features are available mainly on the Search tab, but they are integrated with viewing video in live and playback mode.
Search for video
The Search tab lets you search for video recordings, and - based on the search results - lets you take action, for example by exporting.
The search categories Alarms, Events, People, Vehicles, and Location are only available if you are using one of these products:
  • XProtect Corporate
  • XProtect Expert
You can only combine search categories if you are using one of the products mentioned above. For information about the features available in your XProtect VMS, see Surveillance system differences.
Steps:
  1. Click the arrow to select a predefined time span, or define your own Custom interval.
    Set the timespan while configuring your search in XProtect Smart Client.
  2. In the Selected cameras list, do one of the following to add cameras to your search:
    Select the cameras while configuring your search in XProtect Smart Client.
    • Use the search function to find cameras or views
    • Manually select the cameras in the tree structure. To add all cameras within a view, select the name of the view
    As you add cameras, the search is run immediately.
  3. Click Search for to select the search categories. You can use search categories alone or combined.
    Specify what to search for in XProtect Smart Client.
  4. For each search category that you add, you can refine the search by adding search filters. See also FAQ: searching.
    Search based on motion in XProtect Smart Client.
  5. To preview the video of a search result, select the search result and, in the preview pane, click .
    Preview search results in XProtect Smart Client.
    To play back the video sequence in full-screen mode, double-click the search result.
  6. To make the action bar appear, hover over the search results, one by one, and select the blue check box that appears.
    Search result with the blue check box selected in XProtect Smart Client.
    The blue action bar appears:
    Blue action bar on the Search tab in XProtect Smart Client.
Search for motion (smart search)
When you search for video recordings with motion, you can apply smart searchClosedA search feature that lets you find video with motion in one or more selected areas of recordings from one or more cameras. filters to show only search results with motion in areas that you define.
Steps:
  1. On the Search tab, select a time span.
  2. Select the cameras that you want to include in your search.
  3. Click Search for > Motion > New search. If the database has any recordings with motion within the selected time span and cameras, the recordings appear as thumbnail images in the search results pane.
  4. To find motion in selected areas only:
    1. Below Motion, click 0 cameras selected.
      Search for motion in selected areas in XProtect Smart Client - part one.
      A dialog box appears with a list of the cameras that you selected.
    2. Select one camera at a time and, in the red preview area, click and drag to unmask at least one area. The system will look for motion only in that area. You can unmask multiple areas.
      Search for motion in selected areas in XProtect Smart Client - part two.
      The sensitivity of the motion detection is defined by your system administrator in Management Client on individual cameras. However, you can use the slider to adjust the sensitivity. For more information, see Motion search threshold (explained).
    3. Automatically, the search is run. Click outside the dialog to return to the search results.
    4. To perform actions, for example bookmarking search results, hover over the search results and select the check box . The action bar appears.
When you search for motion in selected areas of a camera, you can adjust the motion threshold. The motion threshold determines how sensitive the motion search mechanism is:
  • The higher the threshold, the more motion is required to activate motion detection. Likely, this will produce fewer search results
  • The lower the threshold, the less motion is required to activate motion detection. Likely, this will produce more search results
Search for bookmarks
You can find incidents that are bookmarked by you or others for any number of cameras.
Steps:
  1. Select the cameras that you want to include in your search.
  2. Click Search for > Bookmark > New search. If the database has any bookmarked recordings, they appear as thumbnail images in the search results pane.
  3. Optionally, enter a keyword to filter the search results. The keyword can be:
    • The full Bookmark ID, for example no.000004
    • Who the bookmark was added by, for example site\user2
    • Any text that appears in the Headline or in the Description
  4. By default, the system will search for the keyword both in the Headline and in the Description. Use Search for keyword in to change that.
  5. To preview the video sequence and bookmark details, select a search result and play back the video in the preview pane on the right-hand side.
    Preview bookmark in XProtect Smart Client.
  6. To view the recording in full-screen mode, double-click the search result.
  7. To perform other actions, for example editing the bookmark, hover over the search result and select the check box . The action bar is displayed.
Search for alarms
When you search for video recordings associated with alarms, you can apply search filters to show only search results with certain alarms, for example alarms in a certain state that are assigned to a specific operator.
Steps:
  2. Click Search for > Alarms > New search.
  3. Apply search filters to narrow down search results. You can filter for:
    • Priority
    • State
    • ID - Type the full ID to filter for it
    • Owner
    • Server - available only if you are using Milestone Federated Architecture™
    If you are using Milestone Federated Architecture™, the Priority and State filters are applied across all connected sites.
Search for events
When you search for video recordings associated with events, you can apply search filters to show only search results with certain events, for example events that come from a specific source or server.
Steps:
  2. Click Search for > Events > New search.
    • Source
Search for people
This search category and its search filters are only available if they were enabled by your system administrator.
When you search for video recordings that include people, you can apply search filters to show only search results with people that have certain characteristics, for example people of a certain age or height.
  2. Click Search for > People > New search.
    • Age - Filter for people in a certain age range
    • Gender - Filter for males or females
    • Height - Filter for people in a certain height range
    • Face - Select the check box to limit search results to people whose face is visible
Search for vehicles
Searching for vehicles is also available if you have XProtect® LPR installed in your system.
For more information, ask your system administrator
When you search for video recordings that include vehicles, you can apply search filters to show only search results with certain vehicles, for example a vehicle with a certain license plate that was issued by a certain country.
  2. Click Search for > Vehicles > New search.
    • Color - Filter for vehicles of certain colors
    • License plate - Type a part of a license plate number or the full license plate number to filter for it
    • Country - Filter for license plates that were issued by certain countries
      This search filter is only available if you have XProtect® LPR installed in your system.
    • Vehicle speed - Filter for vehicles moving at a certain speed
    • Vehicle type - Filter for types of vehicles, for example trucks
    • Match list - Filter for license plates that are part of certain match lists
Search for video at location
When you search for video recordings recorded at a certain location, you can apply search filters to show only search results in a specific location.
  2. Click Search for > Location > New search.
  3. Apply search filters to narrow down search results. You can filter for geographic coordinates by specifying the latitude and longitude coordinates and the radius of the search area.
