Change how a search is configured
You can change how the search is configured, for example the search categories.
The following user permissions are enabled on your role in XProtect Management Client:
- To edit a public search, the Edit public searches user permission must be enabled
On the Search tab, click
to the right of
Search filters.
- In the list that appears, click Open and manage searches. A window appears.
Find and double-click the search that you want to open, or click Open. Immediately, the search is run.
If many searches are listed, use the search function to find the search.
- Modify the search, for example by adding cameras, and click
> Save.
