Content in view items
View items often contain video from cameras, enabling you to see what is going on, but you can also add other types of content to view items:
| Content types | Purposes and benefits |
| Alarms | Share a list of prioritized alarms so XProtect Smart Client users can focus on and respond to alarm-related incidents. |
| Cameras | Show live video feeds or recorded video from cameras. |
| Carousels |
Shows the live video from each camera in a camera group in rotation so you’re aware of what is happening in your area. |
| Hotspots | See video in higher quality in the hotspot view item by selecting a camera in one of the other view items in the same view. |
| Maps and Smart Maps |
Access your cameras and devices on the XProtect VMS system through a geographical map. The map improves the situational awareness in your area. |
| Matrix | You and your colleagues can send live video streams to each other to improve awareness of and collaboration around incidents. |
| Static images | For example, share a snapshot of a suspect or a diagram of emergency exits. |
| Text | For example, send a message, share instructions, or post a work schedule for security personnel. |
| HTML pages | Provide links, online instructions, or show company web pages. |
If your organization uses any of the XProtect extensions, you can also add content related to these extensions:
| Access Monitor | Requires XProtect Access. Add access monitors to your views, for example, for a specific door. |
| LPR | Requires XProtect LPR. Add LPR cameras to your views. |
| Smart Wall controls | Requires XProtect Smart Wall. Push video from cameras and other types of content to your video walls. |
| Transact | Requires XProtect Transact. You can add metadata from, for example, point-of-sales systems to your views. |
