Rules
Your system administrator creates and defines rules that determine how XProtect Smart Client behaves.
Well-defined rules help you focus on what is important, reduce your workload, increase your situational awareness, improve your response times, and improve internal communication in case of incidents.
For example, some rules create events and alarms automatically when an incident occurs. Other rules you activate manually through, for example, overlay buttons inside camera view items.
Here are a few examples:
| Rule example | Rule behavior example | Benefit examples for XProtect Smart Client users |
| Start recording when something happens and stop recording when nothing is going on | The XProtect VMS only saves relevant recordings, for example, 30 seconds before someone opens a gate and 30 seconds after the gate is closed again. | With less recorded video, it is easier to find relevant recordings. |
Improve the quality of the video shown in a view item when something happens |
The XProtect VMS shows the video of the most important incidents in a higher quality. For example, when someone opens a door, the video from the camera surveying the door is shown in higher quality than otherwise in your view. | It is easier to identify the person entering a building. |
| Trigger events and alarms when something happens |
The XProtect VMS notifies you when something specific happens. For example, when a car enters your area. How you’re notified depends on the rule, but a few possible ways are:
You and your colleagues are notified when something happens. |
| Temporarily move a PTZ camera to a specific position, zoom in on what is happening, and return the PTZ camera to its original position after a specified time period. |
The XProtect VMS moves a PTZ camera to cover an area where an incident occurs while zooming in for you to see details better. The PTZ camera returns to its initial position and zoom level, giving you the overview again. An example:
You and your colleagues are presented with the most relevant video and can react quickly. |
| Share live video in Matrix view items when something happens | The XProtect VMS sends live video showing an incident into a view item with Matrix content in one or more shared views. For example, when someone breaches the perimeter of your area. | You and your colleagues are made aware of an critical incident and can react quickly if you need to. |
| Switch cameras between day and night mode based on the time of day | The XProtect VMS switches between cameras’ day/night mode in a specific camera group to display the best video quality. | Ensures you and your colleagues have the best quality live and recorded video. |
