Replace a camera but keep its settings
You can replace a camera in a view but retain the settings for that view item.
  1. On the workspace toolbar, select Setup.
  2. In the Views pane, select the view and camera view item to replace.
  3. In the Properties pane, select the ellipses button next to the Camera name field.
  4. Select the new camera.
  5. Select Setup again to exit setup mode and save your changes.
