Create a view
To create new views with different layouts and content combinations:
On the workspace toolbar, select Setup.
On the Views pane, select the view group to add the view to.
At the bottom of the Views pane, select Create new view
Choose a layout and number of view items.
Name the view.
Select Setup again to exit setup mode and save your changes.
If your system administrator changes camera properties and user permissions in the XProtect VMS system, it may require you to re-create one or more views.
