Export as still images
Click here to download poster.
The following steps are the last steps you need to complete to export video. At this point, you have already added video sequences to the export list and perfected the content for export.
Export a still image for each frame of each video sequence in JPEGClosed An image compression method, also known as JPG or Joint Photographic Experts Group. The method is a so-called lossy compression, meaning that some image detail will be lost during compression. Images compressed this way have become generically known as JPGs or JPEGs. format.
Choosing this format can be relevant if you only need to provide still images as evidence in the exported file.
Steps Action
Select the export format.
Choose whether or not you want to include timestamps.
Start the export.
Give the export a name, add a comment, and choose where to save the export. Select Export.
SC_PPP_ExportStillImages_en-US.pdf
