System requirements
The computer where you want to install the Milestone Open Network Bridge server component must have access to the internet, and the following software must be installed:
  • Microsoft® .NET Framework 3.5.
  • Microsoft® .NET 4.7.2 Framework and Microsoft .NET 6 Runtime installed.
  • Visual C++ Redistributable Package for Visual Studio 2013 (x64).
Cameras must support H.264 or H.265 codecs.
For FIPS 140-2 installations, the Milestone Open Network Bridge uses SHA-256 as a hashing algorith. On computers that do not have FIPS enabled, you can choose between MD5 and SHA-256.
For detailed information on how to configure your XProtect VMS to run in FIPS 140-2 compliant mode, see the FIPS 140-2 compliance section in the hardening guide.
